Need help with conflicting profiles
Hey guys,
I am just new to these forums and Tasker and it has been pretty good. I just have some questions based on the profiles I created.
I created a profile to change my sounds to vibrate only from 2200hrs to 0700hrs. I also created a profile to unmute my phone when I am home. So around 2230hrs (10:30pm), which profile will tasker execute? How do I created a profile so that it is in vibrate mode from 2230-0700 but the rest of the time I am home, my phone is on loud?
Same with battery. I created a profile to disable my bluetooth, auto sync and display brightness if the battery level is below 25%. But now I want to create a profile that once it is charging, I want it to turn back on.
Can someone help me with these profiles? Thanks!
Welcome to Android Forums.
Use one profile with two conditions.
Create the first condition.
Long press on the condition and choose Add .
Add the second condition,
Both conditions need to be met to invoke the entry task.
... Thom
I think what you explained was to add two conditions in order to execute a task.
What I am looking for is..if two conditions with each their own task happens at the same time, then which one executes first? I have a condition from 1030pm-7am to trigger a task (vibrate). I also have another separate condition where my phone rings on loud if my brother calls me. Now I want the second condition to still be able to execute when the first condition is true (i.e. when my brother calls at midnight, I want my phone to ring loud).
Does that make sense?
One profile to turn on vibrate ...
conditions ...
1030pm-8am
and
not (my brother calls)
Another profile make ringer loud ...
condition ...
(my brother calls)
... Thom
I am confused on how to set that up. This is where I am at.
Create new profile using "Time" from 1030pm-7am.
Add a task to turn on vibrate
How do I add the NOT (my brother calls)?
I could be wrong. I was thinking of something like ...
Profile: call
Time: From 22:30 Till 07:00
State: Not Call [ Type:Incoming Number:%Brother ]
Enter: Anon
A1: Ringer Volume [ Level:0 Display:Off Sound:Off ]
A2: Vibrate On Ringer [ Set:On ]
Exit: Anon
A1: Ringer Volume [ Level:7 Display:Off Sound:Off ]
A2: Vibrate On Ringer [ Set:Off ]
Where %Brother is his number
... Thom
