It's all personal choice. For me, I like the screenshot button, because I could never get the power/vol button thing to work.
I like it as well. A touch sensitivity option woulda been a nice touch, to prevent inadvertent screenshots.
Even if you root, that app might be your best bet. I've tried most if not all of the free USB OTG utilities. None work...
I have had zero issues with using OTG for memory sticks, card adaptors, etc. I play movies from a flash drive using MX Player and NMI.
You are correct about OTG being enabled, but not for external memory. That seems self defeating to me, but NMI gets you around the problem for most things. For me, I would rather pay for NMI to solve this little problem than to put up with all the hassles associated with rooting. Rooting causes headaches every time you have an update.
Even if you root, that app might be your best bet. I've tried most if not all of the free USB OTG utilities. None work although USB OTG Helper responds but won't mount a flash drive. I've sent the developer at XDA a log to see if he cn help.
Some people on android forums say they can read USB without utilities.
If they are telling us that they can read external memory plugged into the USB port without using a utility of some kind, and/or being rooted, then they are mistaken. The tablet simply isn't designed to work that way. I'm not actually from Missouri, but I want to see it, if that's what they are claiming. It's not going to happen on a stock machine.
Try THIS.
