Help Need help with sd card
mydoodles
Hi, I just bought a new Huawei-Activa-4G...I also bought a 16GBsd card.....where and how do I change the sd card in my phone.....I have searched the web and can't even find where the sd card is located on my phone. Any help would be so appreciated. Thank you.
Pop of the back of your battery cover and inspect the edges of your phone the sd card should be near the camera on the side of your phone. The battery cover just hides it ;P
Hi MsBaelee and welcome to Android Forums!
If you are referring to moving your applications to the SD card, that is easily done in Settings.
Go to settings --> Apps
Start selecting each application that you can move the SD card. If they can be moved, there will be an option to move it… However, do not move any app that has a widget.
This is not what you are asking, please clarify and we'll try to help you :)
