yoyoitsyourboy
I recently purchased this box named "TUREWELL T95 Max Android 9.0 TV Box" from amazon. Link:https://www.amazon.com/TUREWELL-T95...oid+box&qid=1568140326&s=gateway&sr=8-1-fkmr2
After attaching it to an external touch display, I have found 1. no navigation bar/panel 2. the touch on the display works if and only if I use the mouse cursor that is pre-loaded on the android. There is no way to operate an external touch display without having to control (touch/drag/move) mouse cursor. There also arent any Developer Options mode so I am unable to hide cursor or anything like that. I just want to run my android apps on my touch screen monitor without having to 1. physically always move the mouse cursor 2. not have to use the remote. Any and all suggestions would be hugely appreciated! Thank you!
