I decided to take the plunge and fix my cracked glass Avant with a new digitizer screen and some u tube instruction. The operation seemed to go surprisingly well but somehow i must have disconnected the wifi antenna.
It only detects a wifi network if is right next to the router. When using hotspot it only can beam to a device thats right next to it. Even then its spotty.
Problem is I have no idea where the wifi antenna is. I tried finding the fcc filings but they lead to dead links. Anyone can be of help?
