Need help with Xsbox s805
Hi I've had an Xsbox s805 for a while with no issues. For the last month or so the power cord/jack has been weird. It started having a loose connection first, so I just took it out plugged back in then it would work. Then after a while the cord would only go in half way. I noticed it but wasn't sure if it was always like it or not. So yea, a few days ago it lost power and I tried taking it out and went to put it back in but the cord would not go in at all. Now it just slides back out like its too small or something. Fits perfectly in AV jack but won't fit where it's supposed to go anymore. Also, for a while if I shook the box I'd hear something moving around in there, don't hear it anymore though, maybe there's a part from the cord that got stuck inside the box somehow I'm thinking.
So yea, I need help taking it apart, to check things out maybe look for that piece or fix the jack if its fixable.
I can't find any screw holes or anything, can't slide it apart, anyone know how to take apart the Xsbox s805? Please and thank you, cant find any videos online for this model only other models.
Or maybe you've had this same issue and have a fix?
Thanks in advance for any help I need my tv back, haha.
Look under any labels or decals, might be screws under there, on the other hand there's a good chance the thing is securely glued together and not meant to be taken apart. In which case try prying.
Thanks a lot man for the quick reply. You were right I got it apart by prying at the rubber it was glued on.
It looks like the DC jack fell off the motherboard, I found the spot but cant get it to stay secured there, when the box snaps closed it falls off again.
Anyone have an idea how to get it secured again, or am I in the wrong website all together for that, lol.
