Need help
SHAEBUG
OK ANDRIOD I NEED YOUR HELP I RESETED MY PHONE TO FACTORY SETTINGS AND DIDNT KNOW I WAS GOING TO LOOSE ALL MY CONTACTS IS THERE A POSSIBLE WAY I CAN GET MY CONTACTS BACK:confused:
Hello,
Welcome to the forum. You shouldn't lose your contacts by doing a "reset" at all - but if your contacts are not showing you can do one of two things. 1) Remove and reinsert the battery. 2) Open people/contacts app then tap menu - Tap import/export and then import your contacts to your phone.
I hope this work out for you. Merry Christmas. :)
