Need help
johnyt76
i got a Mtk6575 android 4.0 and lost/forgot pass lock code and cant hard reset it anyone know how i can would much love to hear from ya's cheers :)
Hello and welcome aboard. Thanks for joining the community. ;)
Try doing this: Performing a factory reset using phone buttons
If you can’t turn your phone on or access settings, you can still perform a factory reset by using the phone's buttons. 1. Turn the power off. 2. Press and hold the VOLUME UP and VOLUME DOWN buttons, and then press and hold the POWER button. Release these buttons when your phone turns on and displays a text screen. 3. Keep pressing the VOLUME DOWN button until the Factory reset option is highlighted, and then press the POWER button. 4. Follow the instructions onscreen to proceed with the factory reset.
P.s. Here's a link to http://support.google.com/mail/bin/answer.py?hl=en&answer=12381
