Need Help_Linux deploy will not mount disk image on galaxy tab s 10.5
I'm having problems mounting the Kali Linux disk image evertime I try to install. I thought I didnt have enough memory so I made for sure I had at least 3Gb and still no progress. These are the error messages I recieve everytime.
On linux deploy :
[13:13:29] Updating configuration file ... done
[13:13:30] >>> begin: install
[13:13:30] Checking mount points ... done
[13:13:30] Checking installation path ... done
[13:13:30] Making new disk image (512 MB) ... fail
[13:13:30] <<< end: install
And then in root checker I get this :
Congratulations! You have root access!
Super User Application Status:
SuperSU application by Chainfire - version 2.37 - is installed!
System File Properties for Root Access:
Standard Location
Check Command: ls -l /system/bin/su:
Result: /system/bin/su: No such file or directory
Analysis: File /system/bin/su does not exist.
Standard Location
Check Command: ls -l /system/xbin/su:
Result: -rwxr-xr-x root root 71264 2014-11-30 16:22 su
Analysis: Root access IS correctly configured for this file! Executing this file can grant root access! Root user ownership is present and setuid attribute is not present.
Alternative Location
Check Command: ls -l /sbin/su:
Result: /sbin/su: Permission denied
Analysis: File system permissions restricted and denied access.
Check Command: ls -l /system/xbin/sudo:
Result: /system/xbin/sudo: No such file or directory
Analysis: File /system/xbin/sudo does not exist.
Root User ID and Group ID Status:
Root user id:
uid=0(root)
Root group id:
gid=0(root)
System Environment PATH: /sbin /vendor/bin /system/sbin /system/bin /system/xbin
ADB Shell Default User:
ADB shell setting for standard access, stored in default.prop, is configured as: shell (non root) user - ro.secure=1
Results provided on your SM-T800 - Android 4.4.2 device by Root Checker Pro version 1.3.9 from joeykrim in the Android Market - http://goo.gl/NcnHn
And this with busy box :
BusyBox has been installed correctly!
BusyBox binary location:
/system/xbin/busybox
BusyBox binary file information:
-rwxr-xr-x root root 1048328 2014-12-03 12:55 busybox
Installed BusyBox Version:
1.22.1-Stericson
BusyBox supports the following applets:
[, [[, acpid, adjtimex, arp, arping, ash, awk, base64, basename, beep, blkid, blockdev, brctl, bunzip2, bzcat, bzip2, cal, cat, catv, chat, chattr, chgrp, chmod, chown, chpst, chroot, chrt, chvt, cksum, clear, cmp, comm, conspy, cp, cpio, crond, crontab, cut, date, dc, dd, deallocvt, depmod, devmem, df, diff, dirname, dmesg, dnsd, dnsdomainname, dos2unix, du, dumpkmap, echo, ed, egrep, env, envdir, envuidgid, ether-wake, expand, expr, fakeidentd, false, fbset, fbsplash, fdflush, fdformat, fdisk, fgconsole, fgrep, find, findfs, flock, fold, free, freeramdisk, fsck, fsck.minix, fstrim, fsync, ftpd, ftpget, ftpput, fuser, getopt, grep, groups, gunzip, gzip, hd, hdparm, head, hexdump, hostname, httpd, hush, hwclock, id, ifconfig, ifdown, ifup, inetd, insmod, install, ionice, iostat, ip, ipaddr, ipcalc, iproute, iprule, iptunnel, kbd_mode, kill, killall, killall5, less, ln, loadkmap, losetup, lpd, lpq, lpr, ls, lsattr, lsmod, lsof, lspci, lsusb, lzcat, lzma, lzop, lzopcat, makedevs, man, md5sum, microcom, mkdir, mkdosfs, mke2fs, mkfifo, mkfs.ext2, mkfs.minix, mkfs.vfat, mknod, mkswap, modinfo, modprobe, more, mount, mountpoint, mpstat, mv, nameif, nanddump, nandwrite, nbd-client, nc, netstat, nice, nmeter, nohup, nslookup, ntpd, od, openvt, patch, pgrep, pidof, ping, ping6, pipe_progress, pivot_root, pkill, pmap, powertop, printenv, printf, ps, pscan, pstree, pwd, pwdx, raidautorun, rdate, rdev, readahead, readlink, readprofile, realpath, renice, reset, resize, rev, rm, rmdir, rmmod, route, rpm, rpm2cpio, rtcwake, run-parts, runsv, runsvdir, rx, script, scriptreplay, sed, seq, setconsole, setkeycodes, setlogcons, setserial, setsid, setuidgid, sha1sum, sha256sum, sha3sum, sha512sum, showkey, slattach, sleep, smemcap, softlimit, sort, split, start-stop-daemon, stat, strings, stty, sum, sv, svlogd, swapoff, swapon, switch_root, sync, sysctl, tac, tail, tar, tcpsvd, tee, telnet, telnetd, test, tftp, tftpd, time, timeout, top, touch, tr, traceroute, traceroute6, true, tty, ttysize, tunctl, ubiattach, ubidetach, ubimkvol, ubirmvol, ubirsvol, ubiupdatevol, udpsvd, umount, uname, unexpand, uniq, unix2dos, unlzma, unlzop, unxz, unzip, uptime, usleep, uudecode, uuencode, vconfig, vi, volname, watch, watchdog, wc, wget, which, whoami, whois, xargs, xz, xzcat, yes, zcat, zcip
Can you tell me what I could possibly be doing wrong?
Thank You
AO!
