SilentR3venge
Member
Could someone please upload the mixer_paths.xml? I accidentally deleted it, resulting in no sound whatsoever. I have tried the xml for the fierce 2 and a couple other random ones. HTC provides the firmware on their website. I am in the process of extracting the HTC desire 626s rom since the phone has the same chipset, processor, and graphics card. Look forward to getting the audio back soon
If someone could still upload the file. I wish I could find some source code for this phone!
I just found a "mixer_paths.xml" from a phone with the same version of lollipop. The Hauwei Cherry Cyanogenmod 13 xml. The only problem is the speaker doesn't work. music plays through the handset.
Code:
<?xml version="1.0" encoding="ISO-8859-1"?>
Copyright (c) 2014, The Linux Foundation. All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are
met:
* Redistributions of source code must retain the above copyright
notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above
copyright notice, this list of conditions and the following
disclaimer in the documentation and/or other materials provided
with the distribution.
* Neither the name of The Linux Foundation nor the names of its
contributors may be used to endorse or promote products derived
from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESS OR IMPLIED
WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN
IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
<mixer>
<!-- These are the initial mixer settings -->
<ctl name="Voice Rx Device Mute" id="0" value="0" />
<ctl name="Voice Rx Device Mute" id="1" value="-1" />
<ctl name="Voice Rx Device Mute" id="2" value="20" />
<ctl name="Voice Tx Mute" id="0" value="0" />
<ctl name="Voice Tx Mute" id="1" value="-1" />
<ctl name="Voice Tx Mute" id="2" value="500" />
<ctl name="Voice Rx Gain" id="0" value="0" />
<ctl name="Voice Rx Gain" id="1" value="-1" />
<ctl name="Voice Rx Gain" id="2" value="20" />
<ctl name="Voip Tx Mute" id="0" value="0" />
<ctl name="Voip Tx Mute" id="1" value="500" />
<ctl name="Voip Rx Gain" id="0" value="0" />
<ctl name="Voip Rx Gain" id="1" value="20" />
<ctl name="Voip Mode Config" value="12" />
<ctl name="Voip Rate Config" value="0" />
<ctl name="Voip Evrc Min Max Rate Config" id="0" value="1" />
<ctl name="Voip Evrc Min Max Rate Config" id="1" value="4" />
<ctl name="Voip Dtx Mode" value="0" />
<ctl name="TTY Mode" value="Off" />
<ctl name="HPHL Volume" value="9" />
<ctl name="HPHR Volume" value="9" />
<ctl name="RX1 Digital Volume" value="92" />
<ctl name="RX2 Digital Volume" value="92" />
<ctl name="RX3 Digital Volume" value="84" />
<ctl name="IIR1 INP1 Volume" value="84" />
<ctl name="IIR1 INP2 Volume" value="84" />
<ctl name="IIR1 INP3 Volume" value="84" />
<ctl name="IIR1 INP4 Volume" value="84" />
<ctl name="ADC1 Volume" value="13" />
<ctl name="ADC2 Volume" value="13" />
<ctl name="ADC3 Volume" value="13" />
<ctl name="DEC1 Volume" value="84" />
<ctl name="DEC2 Volume" value="84" />
<ctl name="DEC2 MUX" value="ZERO" />
<ctl name="DEC1 MUX" value="ZERO" />
<ctl name="ADC2 MUX" value="ZERO" />
<ctl name="RDAC2 MUX" value="ZERO" />
<ctl name="RX2 MIX2 INP2" value="ZERO" />
<ctl name="RX2 MIX2 INP1" value="ZERO" />
<ctl name="RX1 MIX2 INP2" value="ZERO" />
<ctl name="RX1 MIX2 INP1" value="ZERO" />
<ctl name="RX3 MIX1 INP2" value="ZERO" />
<ctl name="RX3 MIX1 INP1" value="ZERO" />
<ctl name="RX2 MIX1 INP2" value="ZERO" />
<ctl name="RX2 MIX1 INP1" value="ZERO" />
<ctl name="RX1 MIX1 INP2" value="ZERO" />
<ctl name="RX1 MIX1 INP1" value="ZERO" />
<ctl name="EAR_S" value="ZERO" />
<ctl name="HPHL" value="ZERO" />
<ctl name="HPHR" value="ZERO" />
<ctl name="SPK DAC Switch" value="0" />
<ctl name="Speaker Boost" value="DISABLE" />
<ctl name="MICBIAS CAPLESS Switch" value="0" />
<ctl name="EAR PA Boost" value="DISABLE" />
<ctl name="EAR PA Gain" value="POS_6_DB" />
<ctl name="MI2S_RX Channels" value="One" />
<ctl name="MI2S_TX Channels" value="One" />
<ctl name="SPK" value="ON" />
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia1" value="0" />
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia1" value="0" />
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia4" value="0" />
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia4" value="0" />
<ctl name="AFE_PCM_RX Audio Mixer MultiMedia4" value="0" />
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia4" value="0" />
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia5" value="0" />
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia5" value="0" />
<ctl name="MultiMedia1 Mixer TERT_MI2S_TX" value="0" />
<ctl name="MultiMedia5 Mixer TERT_MI2S_TX" value="0" />
<ctl name="MultiMedia1 Mixer INTERNAL_BT_SCO_TX" value="0" />
<ctl name="PRI_MI2S_RX_Voice Mixer CSVoice" value="0" />
<ctl name="Voice_Tx Mixer TERT_MI2S_TX_Voice" value="0" />
<ctl name="PRI_MI2S_RX Port Mixer INT_BT_SCO_TX" value="0" />
<!-- Voice BTSCO -->
<ctl name="Internal BTSCO SampleRate" value="8000" />
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer CSVoice" value="0" />
<ctl name="Voice_Tx Mixer INTERNAL_BT_SCO_TX_Voice" value="0" />
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer Multimedia6" value="0" />
<ctl name="MultiMedia6 Mixer TERT_MI2S_TX" value="0" />
<!-- Voice2 -->
<ctl name="PRI_MI2S_RX_Voice Mixer Voice2" value="0" />
<ctl name="Voice2_Tx Mixer TERT_MI2S_TX_Voice2" value="0" />
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer Voice2" value="0" />
<ctl name="Voice2_Tx Mixer INTERNAL_BT_SCO_TX_Voice2" value="0" />
<ctl name="AFE_PCM_RX_Voice Mixer Voice2" value="0" />
<ctl name="Voice2_Tx Mixer AFE_PCM_TX_Voice2" value="0" />
<!-- Voice2 end -->
<!-- VoWLAN -->
<ctl name="PRI_MI2S_RX_Voice Mixer VoWLAN" value="0" />
<ctl name="VoWLAN_Tx Mixer TERT_MI2S_TX_VoWLAN" value="0" />
<ctl name="HDMI_RX_Voice Mixer VoWLAN" value="0" />
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer VoWLAN" value="0" />
<ctl name="VoWLAN_Tx Mixer INTERNAL_BT_SCO_TX_VoWLAN" value="0" />
<ctl name="AFE_PCM_RX_Voice Mixer VoWLAN" value="0" />
<ctl name="VoWLAN_Tx Mixer AFE_PCM_TX_VoWLAN" value="0" />
<!-- VoWLAN -->
<!-- Voip -->
<ctl name="PRI_MI2S_RX_Voice Mixer Voip" value="0" />
<ctl name="Voip_Tx Mixer TERT_MI2S_TX_Voip" value="0" />
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer Voip" value="0" />
<ctl name="Voip_Tx Mixer INTERNAL_BT_SCO_TX_Voip" value="0" />
<!-- Voip end -->
<!-- fm -->
<ctl name="Internal FM RX Volume" value="0" />
<ctl name="PRI_MI2S_RX Port Mixer INTERNAL_FM_TX" value="0" />
<ctl name="MI2S_DL_HL Switch" value="1" />
<ctl name="MultiMedia1 Mixer INTERNAL_FM_TX" value="0" />
<ctl name="MultiMedia2 Mixer INTERNAL_FM_TX" value="0" />
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia1" value="0" />
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia5" value="0" />
<!-- fm end -->
<!-- Incall Recording -->
<ctl name="MultiMedia1 Mixer VOC_REC_UL" value="0" />
<ctl name="MultiMedia1 Mixer VOC_REC_DL" value="0" />
<!-- Incall Recording end -->
<!-- Incall Music -->
<ctl name="Incall_Music Audio Mixer MultiMedia2" value="0" />
<ctl name="Incall_Music_2 Audio Mixer MultiMedia9" value="0" />
<!-- Incall Music End -->
<!-- QCHAT -->
<ctl name="PRI_MI2S_RX_Voice Mixer QCHAT" value="0" />
<ctl name="QCHAT_Tx Mixer TERT_MI2S_TX_QCHAT" value="0" />
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer QCHAT" value="0" />
<ctl name="QCHAT_Tx Mixer INTERNAL_BT_SCO_TX_QCHAT" value="0" />
<!-- QCHAT End -->
<!-- EC_REF -->
<ctl name="AUDIO_REF_EC_UL1 MUX" value="None" />
<!-- IIR -->
<ctl name="IIR1 Band1" id ="0" value="268435456" />
<ctl name="IIR1 Band1" id ="1" value="0" />
<ctl name="IIR1 Band1" id ="2" value="0" />
<ctl name="IIR1 Band1" id ="3" value="0" />
<ctl name="IIR1 Band1" id ="4" value="0" />
<ctl name="IIR1 Band2" id ="0" value="268435456" />
<ctl name="IIR1 Band2" id ="1" value="0" />
<ctl name="IIR1 Band2" id ="2" value="0" />
<ctl name="IIR1 Band2" id ="3" value="0" />
<ctl name="IIR1 Band2" id ="4" value="0" />
<ctl name="IIR1 Band3" id ="0" value="268435456" />
<ctl name="IIR1 Band3" id ="1" value="0" />
<ctl name="IIR1 Band3" id ="2" value="0" />
<ctl name="IIR1 Band3" id ="3" value="0" />
<ctl name="IIR1 Band3" id ="4" value="0" />
<ctl name="IIR1 Band4" id ="0" value="268435456" />
<ctl name="IIR1 Band4" id ="1" value="0" />
<ctl name="IIR1 Band4" id ="2" value="0" />
<ctl name="IIR1 Band4" id ="3" value="0" />
<ctl name="IIR1 Band4" id ="4" value="0" />
<ctl name="IIR1 Band5" id ="0" value="268435456" />
<ctl name="IIR1 Band5" id ="1" value="0" />
<ctl name="IIR1 Band5" id ="2" value="0" />
<ctl name="IIR1 Band5" id ="3" value="0" />
<ctl name="IIR1 Band5" id ="4" value="0" />
<ctl name="IIR1 Enable Band1" value="0" />
<ctl name="IIR1 Enable Band2" value="0" />
<ctl name="IIR1 Enable Band3" value="0" />
<ctl name="IIR1 Enable Band4" value="0" />
<ctl name="IIR1 Enable Band5" value="0" />
<!-- IIR -->
<!-- ADSP testfwk -->
<ctl name="MI2S_DL_HL Switch" value="0" />
<!-- ADSP testfwk end-->
<path name="bt-sco-wb-samplerate">
<ctl name="Internal BTSCO SampleRate" value="16000" />
</path>
<!-- These are audio route (FE to BE) specific mixer settings -->
<path name="deep-buffer-playback">
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia1" value="1" />
</path>
<path name="deep-buffer-playback bt-sco">
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia1" value="1" />
</path>
<path name="deep-buffer-playback bt-sco-wb">
<path name="deep-buffer-playback bt-sco" />
</path>
<path name="deep-buffer-playback afe-proxy">
<ctl name="AFE_PCM_RX Audio Mixer MultiMedia1" value="1" />
</path>
<path name="deep-buffer-playback usb-headphones">
<path name="deep-buffer-playback afe-proxy" />
</path>
<path name="deep-buffer-playback speaker-and-usb-headphones">
<path name="deep-buffer-playback usb-headphones" />
<path name="deep-buffer-playback" />
</path>
<path name="deep-buffer-playback transmission-fm">
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia1" value="1" />
</path>
<path name="low-latency-playback">
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia5" value="1" />
</path>
<path name="low-latency-playback bt-sco">
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia5" value="1" />
</path>
<path name="low-latency-playback bt-sco-wb">
<path name="low-latency-playback bt-sco" />
</path>
<path name="low-latency-playback afe-proxy">
<ctl name="AFE_PCM_RX Audio Mixer MultiMedia5" value="1" />
</path>
<path name="low-latency-playback usb-headphones">
<path name="low-latency-playback afe-proxy" />
</path>
<path name="low-latency-playback speaker-and-usb-headphones">
<path name="low-latency-playback usb-headphones" />
<path name="low-latency-playback" />
</path>
<path name="low-latency-playback transmission-fm">
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia5" value="1" />
</path>
<path name="compress-offload-playback">
<ctl name="PRI_MI2S_RX Audio Mixer MultiMedia4" value="1" />
</path>
<path name="compress-offload-playback bt-sco">
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia4" value="1" />
</path>
<path name="compress-offload-playback bt-sco-wb">
<path name="compress-offload-playback bt-sco" />
</path>
<path name="compress-offload-playback afe-proxy">
<ctl name="AFE_PCM_RX Audio Mixer MultiMedia4" value="1" />
</path>
<path name="compress-offload-playback usb-headphones">
<path name="compress-offload-playback afe-proxy" />
</path>
<path name="compress-offload-playback speaker-and-usb-headphones">
<path name="compress-offload-playback usb-headphones" />
<path name="compress-offload-playback" />
</path>
<path name="compress-offload-playback transmission-fm">
<ctl name="INTERNAL_FM_RX Audio Mixer MultiMedia4" value="1" />
</path>
<path name="audio-record">
<ctl name="MultiMedia1 Mixer TERT_MI2S_TX" value="1" />
</path>
<!-- listen -->
<ctl name="LSM1 MUX" value="None" />
<ctl name="LSM2 MUX" value="None" />
<ctl name="LSM3 MUX" value="None" />
<ctl name="LSM4 MUX" value="None" />
<ctl name="LSM5 MUX" value="None" />
<ctl name="TERT_MI2S_TX LSM Function" value="None" />
<!-- listen end-->
<path name="audio-record bt-sco">
<ctl name="MultiMedia1 Mixer INTERNAL_BT_SCO_TX" value="1" />
</path>
<path name="audio-record bt-sco-wb">
<path name="audio-record bt-sco" />
</path>
<path name="audio-record usb-headset-mic">
<ctl name="MultiMedia1 Mixer AFE_PCM_TX" value="1" />
</path>
<path name="audio-record capture-fm">
<ctl name="MultiMedia1 Mixer INTERNAL_FM_TX" value="1" />
</path>
<path name="low-latency-record">
<ctl name="MultiMedia5 Mixer TERT_MI2S_TX" value="1" />
</path>
<path name="fm-virtual-record capture-fm">
<ctl name="MultiMedia2 Mixer INTERNAL_FM_TX" value="1" />
</path>
<path name="voice-call">
<ctl name="PRI_MI2S_RX_Voice Mixer CSVoice" value="1" />
<ctl name="Voice_Tx Mixer TERT_MI2S_TX_Voice" value="1" />
</path>
<path name="voice-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer CSVoice" value="1" />
<ctl name="Voice_Tx Mixer INTERNAL_BT_SCO_TX_Voice" value="1" />
</path>
<path name="voice-call bt-sco-wb">
<path name="voice-call bt-sco" />
</path>
<path name="voice-call usb-headphones">
<ctl name="AFE_PCM_RX_Voice Mixer CSVoice" value="1" />
<ctl name="Voice_Tx Mixer AFE_PCM_TX_Voice" value="1" />
</path>
<path name="voice2-call">
<ctl name="PRI_MI2S_RX_Voice Mixer Voice2" value="1" />
<ctl name="Voice2_Tx Mixer TERT_MI2S_TX_Voice2" value="1" />
</path>
<path name="voice2-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer Voice2" value="1" />
<ctl name="Voice2_Tx Mixer INTERNAL_BT_SCO_TX_Voice2" value="1" />
</path>
<path name="voice2-call bt-sco-wb">
<path name="voice2-call bt-sco" />
</path>
<path name="voice2-call usb-headphones">
<ctl name="AFE_PCM_RX_Voice Mixer Voice2" value="1" />
<ctl name="Voice2_Tx Mixer AFE_PCM_TX_Voice2" value="1" />
</path>
<path name="play-fm">
<ctl name="Internal FM RX Volume" value="1" />
<ctl name="PRI_MI2S_RX Port Mixer INTERNAL_FM_TX" value="1" />
</path>
<path name="vowlan-call">
<ctl name="PRI_MI2S_RX_Voice Mixer VoWLAN" value="1" />
<ctl name="VoWLAN_Tx Mixer TERT_MI2S_TX_VoWLAN" value="1" />
</path>
<path name="vowlan-call hdmi">
<ctl name="HDMI_RX_Voice Mixer VoWLAN" value="1" />
</path>
<path name="vowlan-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer VoWLAN" value="1" />
<ctl name="VoWLAN_Tx Mixer INTERNAL_BT_SCO_TX_VoWLAN" value="1" />
</path>
<path name="vowlan-call bt-sco-wb">
<path name="vowlan-call bt-sco" />
</path>
<path name="vowlan-call usb-headphones">
<ctl name="AFE_PCM_RX_Voice Mixer VoWLAN" value="1" />
<ctl name="VoWLAN_Tx Mixer AFE_PCM_TX_VoWLAN" value="1" />
</path>
<path name="hfp-sco">
<ctl name="PRI_MI2S_RX Port Mixer INTERNAL_BT_SCO_TX" value="1" />
<ctl name="INTERNAL_BT_SCO_RX Audio Mixer MultiMedia6" value="1" />
<ctl name="MultiMedia6 Mixer TERT_MI2S_TX" value="1" />
</path>
<path name="hfp-sco-wb">
<path name="hfp-sco" />
</path>
<path name="incall-rec-uplink">
<ctl name="MultiMedia1 Mixer VOC_REC_UL" value="1" />
</path>
<path name="incall-rec-uplink bt-sco">
<path name="incall-rec-uplink" />
</path>
<path name="incall-rec-uplink bt-sco-wb">
</path>
<path name="incall-rec-downlink">
<ctl name="MultiMedia1 Mixer VOC_REC_DL" value="1" />
</path>
<path name="incall-rec-downlink bt-sco">
<path name="incall-rec-downlink" />
</path>
<path name="incall-rec-downlink bt-sco-wb">
</path>
<path name="incall-rec-uplink-and-downlink">
</path>
<path name="incall-rec-uplink-and-downlink bt-sco">
<path name="incall-rec-uplink-and-downlink" />
</path>
<path name="incall-rec-uplink-and-downlink bt-sco-wb">
</path>
<path name="incall_music_uplink">
<ctl name="Incall_Music Audio Mixer MultiMedia2" value="1" />
</path>
<path name="incall_music_uplink2">
<ctl name="Incall_Music_2 Audio Mixer MultiMedia9" value="1" />
</path>
<path name="volte-call">
<ctl name="PRI_MI2S_RX_Voice Mixer VoLTE" value="1" />
<ctl name="VoLTE_Tx Mixer TERT_MI2S_TX_VoLTE" value="1" />
</path>
<path name="volte-call hdmi">
<ctl name="HDMI_RX_Voice Mixer VoLTE" value="1" />
<ctl name="VoLTE_Tx Mixer SLIM_0_TX_VoLTE" value="1" />
</path>
<path name="volte-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer VoLTE" value="1" />
<ctl name="VoLTE_Tx Mixer INTERNAL_BT_SCO_TX_VoLTE" value="1" />
</path>
<path name="volte-call bt-sco-wb">
<path name="volte-call bt-sco" />
</path>
<path name="volte-call usb-headphones">
<ctl name="AFE_PCM_RX_Voice Mixer VoLTE" value="1" />
<ctl name="VoLTE_Tx Mixer AFE_PCM_TX_VoLTE" value="1" />
</path>
<path name="compress-voip-call">
<ctl name="PRI_MI2S_RX_Voice Mixer Voip" value="1" />
<ctl name="Voip_Tx Mixer TERT_MI2S_TX_Voip" value="1" />
</path>
<path name="compress-voip-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer Voip" value="1" />
<ctl name="Voip_Tx Mixer INTERNAL_BT_SCO_TX_Voip" value="1" />
</path>
<path name="compress-voip-call bt-sco-wb">
<path name="compress-voip-call bt-sco" />
</path>
<path name="listen-voice-wakeup-1">
<ctl name="LSM1 MUX" value="TERT_MI2S_TX" />
<ctl name="TERT_MI2S_TX LSM Function" value="SWAUDIO" />
</path>
<path name="listen-voice-wakeup-2">
<ctl name="LSM2 MUX" value="TERT_MI2S_TX" />
</path>
<path name="listen-voice-wakeup-3">
<ctl name="LSM3 MUX" value="TERT_MI2S_TX" />
</path>
<path name="listen-voice-wakeup-4">
<ctl name="LSM4 MUX" value="TERT_MI2S_TX" />
</path>
<path name="listen-voice-wakeup-5">
<ctl name="LSM5 MUX" value="TERT_MI2S_TX" />
</path>
<path name="qchat-call">
<ctl name="PRI_MI2S_RX_Voice Mixer QCHAT" value="1" />
<ctl name="QCHAT_Tx Mixer TERT_MI2S_TX_QCHAT" value="1" />
</path>
<path name="qchat-call bt-sco">
<ctl name="INTERNAL_BT_SCO_RX_Voice Mixer QCHAT" value="1" />
<ctl name="QCHAT_Tx Mixer INTERNAL_BT_SCO_TX_QCHAT" value="1" />
</path>
<path name="qchat-call bt-sco-wb">
<path name="qchat-call bt-sco" />
</path>
<!-- These are actual sound device specific mixer settings -->
<path name="adc1">
<ctl name="DEC1 MUX" value="ADC1" />
</path>
<path name="adc2">
<ctl name="DEC1 MUX" value="ADC2" />
</path>
<path name="adc3">
<ctl name="ADC2 MUX" value="INP3" />
</path>
<path name="speaker">
<ctl name="RX3 MIX1 INP1" value="RX1" />
<ctl name="SPK DAC Switch" value="1" />
</path>
<path name="speaker-mic">
<path name="adc1" />
<ctl name="IIR1 INP1 MUX" value="DEC1" />
<ctl name="ADC1 Volume" value="6" />
</path>
<path name="handset">
<ctl name="EAR PA Boost" value="ENABLE" />
<ctl name="RX1 MIX1 INP1" value="RX1" />
<ctl name="RDAC2 MUX" value="RX1" />
<ctl name="EAR_S" value="Switch" />
</path>
<path name="handset-mic">
</path>
<path name="headphones">
<ctl name="MI2S_RX Channels" value="Two" />
<ctl name="RX2 MIX1 INP1" value="RX2" />
<ctl name="RDAC2 MUX" value="RX2" />
<ctl name="HPHL" value="Switch" />
<ctl name="HPHR" value="Switch" />
</path>
<path name="headset-mic">
<path name="adc2" />
<ctl name="MICBIAS CAPLESS Switch" value="1" />
<ctl name="ADC2 MUX" value="INP2" />
<ctl name="ADC2 Volume" value="6" />
</path>
<path name="sidetone-iir">
<ctl name="IIR1 Enable Band1" value="1" />
<ctl name="IIR1 Enable Band2" value="1" />
<ctl name="IIR1 Enable Band3" value="1" />
<ctl name="IIR1 Enable Band4" value="1" />
<ctl name="IIR1 Enable Band5" value="1" />
</path>
<path name="sidetone-handset">
<path name="sidetone-iir" />
<ctl name="IIR1 INP1 Volume" value="0" />
<ctl name="RX1 MIX2 INP1" value="IIR1" />
</path>
<path name="sidetone-headphone">
<ctl name="RX2 MIX2 INP1" value="IIR1" />
</path>
<path name="voice-handset">
<path name="sidetone-handset" />
<path name="handset" />
</path>
<path name="voice-speaker">
<path name="speaker" />
</path>
<path name="voice-speaker-mic">
<path name="speaker-mic" />
</path>
<path name="voice-headphones">
<path name="headphones" />
</path>
<path name="voice-headset-mic">
<path name="headset-mic" />
</path>
<path name="speaker-and-headphones">
</path>
<path name="usb-headphones">
</path>
<path name="afe-proxy">
</path>
<path name="transmission-fm">
</path>
<path name="speaker-and-usb-headphones">
<path name="usb-headphones" />
</path>
<path name="voice-rec-mic">
<path name="handset-mic" />
</path>
<path name="camcorder-mic">
</path>
<path name="bt-sco-headset">
</path>
<path name="bt-sco-mic">
</path>
<path name="bt-sco-headset-wb">
</path>
<path name="bt-sco-mic-wb">
</path>
<path name="usb-headset-mic">
</path>
<path name="capture-fm">
</path>
<!-- Dual MIC devices -->
<path name="speaker-dmic-endfire">
<ctl name="DEC2 MUX" value="ADC2" />
<ctl name="MI2S_TX Channels" value="Two" />
<ctl name="ADC3 Volume" value="6" />
</path>
<path name="dmic-endfire">
<path name="speaker-dmic-endfire" />
</path>
<path name="voice-dmic-ef-tmus">
<path name="dmic-endfire" />
</path>
<path name="voice-dmic-ef">
</path>
<path name="voice-speaker-dmic-ef">
</path>
<path name="voice-rec-dmic-ef">
</path>
<path name="voice-rec-dmic-ef-fluence">
</path>
<path name="handset-stereo-dmic-ef">
</path>
<path name="speaker-stereo-dmic-ef">
</path>
<path name="speaker-dmic-broadside">
<path name="adc3" />
<ctl name="DEC2 MUX" value="ADC1" />
</path>
<path name="dmic-broadside">
<path name="speaker-dmic-broadside" />
</path>
<path name="voice-speaker-dmic-broadside">
<path name="dmic-broadside"/>
</path>
<path name="echo-reference">
<ctl name="AUDIO_REF_EC_UL1 MUX" value="I2S_RX" />
</path>
<!-- TTY devices -->
<path name="tty-headphones">
</path>
<path name="voice-tty-full-headphones">
<ctl name="TTY Mode" value="FULL" />
<path name="tty-headphones" />
</path>
<path name="voice-tty-vco-headphones">
<ctl name="TTY Mode" value="VCO" />
</path>
<path name="voice-tty-hco-handset">
<ctl name="TTY Mode" value="HCO" />
</path>
<path name="voice-tty-full-headset-mic">
</path>
<path name="voice-tty-hco-headset-mic">
<path name="voice-tty-full-headset-mic" />
</path>
<path name="voice-tty-vco-handset-mic">
</path>
<path name="listen-handset-mic">
</path>
<path name="ADSP testfwk">
</path>
</mixer>
