need offlline dictionary for 2.1
thnks bro but i cant download applications directly on my phone .. since i dont have net on my phone yet..... can u tell me how i can download it on my pc , so that then i can transfer to my phone
Might have been handy to mention that earlier!
You will need to download a dictionary .apk file to your computer...
http://www.google.co.uk/search?hl=&...avclient-ff&rlz=1B3GGGL_enGB301GB301&ie=UTF-8
You will then need to transfer it to your SD card and install...
http://www.youtube.com/watch?v=7UOAw124y1s
Huh?
You have a phone, but not a working connection for it?
Did you buy that phone without a subscription/connection, or did you just 'find' it?
haha dude its my phone i have buy it... actualy i m from india... and here mostly phones are sold without subscription/connection ... becoz here we mostly used gsm rather than cdma
Well, you have a phone, and a subscription "is almost as good as free"! I would be chomping at the bit to get that connection, install everything, and get it all working.
You're the boss over its use, and you can for instance disable mobile data use, so that you only use data when connected to WiFi hotspots.
BTW, a socalled 'unlimited mobile data plan' is not unlimited at all. It is governed by a "fair use policy" cap. But if you don't use streaming video, watch live TV, or game a lot, that limited "unlimited data plan" is enough for most users. But exceeding it can get expensive.
android offline dictionary download .apk - Google Search
BRO I HAVE DOWNLOADED IT AND TRANSFER IT TO MY PHONE SD CARD BUT AFTR INSTALLING NOW WHEN I M OPNEING IT IT SHOWING
error-
HOSI IS UNRESOLVED:
MOBISYSTEMS.COM:80
i am having sony x8 ( version 2.1)
