So Im in desperate need of at least one more Wall charge for my galaxy note 8.0 and Galaxy S4. The only problem is they're either pretty expensive for the more legit products, or sketchy. I just need the white box part that goes into the wall outlet. SO incredibly embarrassing and frustrating that I can't seem to figure out what it's actually called. In any case, through my searches I found this:
Qmadix 4.4A USB Triple Travel Charging Hub
It allows for three ports, but each port is designated differently. well, okay... two are the same (1A), but ones different (2.4A). I have no clue about electricity, except to know if you don't use the samsung recommended converters it could damage the battery in the long run. Im under the impression that both of my devices require 2.0A. Does this mean only the 2.4A port would work?
Is anyone familiar with this Item Ive listed? Could I use this device to power bot my Galaxy Note 8.0 AND Galaxy S4 at the same time?
It seems like such a great deal and very compact. Can't pass up without at least asking about it.
again, Im asking about the:
