Need some help understanding something in the battery settings
ashenfang
So recently my phone (verizon note 3) started having terrible battery life. Nothing changed, no new apps or settings ect. So I check under the battery settings to see if I can find out what the problem application might be. However, what I found was my "Time on Battery" and "Awake" were exactly the same. After researching the forums I found that under normal circumstances, the "Time on battery" should be more than "Awake time". For instance, on my phone, it says, Time on Battery = 8h 5min, and Awake Time = 8hr 5min. So my phone is "awake" even though the phone screen is not on, which by the way, screen time is 2h 36min. I am having trouble figuring out why my phone is "awake" and hopefully you guys here have some suggestions.
Thanks!
You need to see which app is creating a wake lock. Try gettings GSAM battery stats and look which app is always awake.
using GSAM, I selected "view time held awake" and the largest is Kernel (Android OS), and then "System", but combined they are only 10 minutes or so. That doesn't account for over 8 hours of "awake" time that the battery is showing.
actually I should add that I did reboot the phone so my awake times will be smaller. However, I did notice that "System" Wake lock is now the largest user. With 6m 55s of wake time. Wake lock detail says audoiout_2 6.9m (92), and included processes lists wake lock and media server.
