Firstly, does it work on my dInc on VZW? I have read posts that say it doesnt, i am just not sure.
Then assuming it does, can anyone recommend settings? 1/15 appears to be the common, how do i set that?
Also I had a minor problem with gmail earlier, where it wouldnt load conversations or send emails. I was not on Wifi. Can this be related to JuiceDefender? I freaked out when i had no data
does the 1/15 mean that even if i send something, it wont go out until that data is turned back on? I thought that only effected sync accounts or something. An explanation of how that works would be great
