need some some help on internet connection with laptop
Guyz i surf internt on my laptop by connecting my phone using pdanet. But speed on laptop is very slow as compared to speed which i get when i surf on my phone . can anybody tell me is it normal to get less speed on laptop or i should use any other software or method to connect my phone
I've never used pdanet, but the reviews I read when I was looking for a tether said it was pretty slow. I use easythether pro. 10 bucks (one time charge) and its about the same speed as a decent wifi. Connection.
I guess it depends on your phone's connection. My 3g with pdanet is ok..doesn't seem much slower than my phone... when I have a 4G connection its fast!
Well thats wht i wana to know does software effects speed like pdanet, tethyer or any other ? Becoz when i surf on my phone speed is very nice as compare to laptop
Well when you surf on your phone you are going to mobile sites that are way smaller in size than desktop sites.
The way to figure out the problem is this: download the SpeedTest.net app on the phone. Do a couple of speed tests and average the results. THen connect to pdanet, go to speedtest.net on your computer, and average the results. They should be similar speeds.
Well thnkz guyz.... For so many responses.... Sitlet i m opening same sites .... Main point is Download speed which is one-third or even one-fourth on laptop as compare to mobile..... But aftr seeing responses i thinhk its normal nd i wont get same speed
No, that is not normal. If you are getting high speeds when doing speed tests on the phone, and aren't getting the same speeds with pdanet, then you have a problem on the computer end. Make sure you have the right drivers for the phone installed. Make sure you have the right pdanet installed.
