Do you mean you deleted the navigation app? If so, back up your other apps and factory reset (as long as you aren't rooted) in settings, and it will return the phone to its original state. Then restore and you are good to go.
You might also want to join forums and go to the Verizon Siii threads. Folks on here are really helpful.
