Hi everyone! I got the android LG cell, and I got the quicksettings app from market. I follow step by step, but it still not working. It says "network unnavailable" please help me, I can't afford to pay for wifi in my home, thanks a lot!
That sounds like one of two things: either the application has some problems connecting to your network, or your device isn't having a strong enough signal.
If you had WiFi it would be a little easier to narrow down the problem. I've had an application that would not work when I use my 3g or 4G connections - it only works over WiFi. Which was very strange. I contacted the developer about the problem, and it was fixed with their next update.
You should try discussing this problem with either the app developer, or your network carrier.
