I was trying to add something and kind fooled up my android so I did a restore and now I do not have any movies I need help to know what I should do tks
Could you be a bit more specific about what you were trying to add, what got fooled up, and what you did to restore things? Also, what device do you have, and is it stock or rooted?
It's pretty tough for us to troubleshoot a problem that we can't see or touch without a solid explanation of what actually happened.
If you did not have a backup copy on a computer or cloud storage, then unfortunately the files are gone. Sorry.
But...if they were on a removable SD card, then even if they appear to be gone you may be able to recover them by putting the SD card in a laptop or PC with a card slot or USB card reader and using Recuva software:
