TVCCS
I have two phones currently sharing one NET10 AT&T BYOP SIM card and wanted to share the APN settings, as they vary from one device to the next, even using the same SIM card.
Setup 1: (Samsung Captivate Glide)
APN: wap.tracfone
Proxy: Not set
Port: Not set
User Name: Not set
Password: Not set
Server: Not set
MMSC: http://mmsc.cingular.com
MMS proxy: 66.209.11.32
MMS Port: 80
MCC: 310
MNC: 410
Authentication type: Not Set
APN type: Internet+mms+supl
Setup 2: (Motorola Atrix 2) - Initial settings & instructions as provided by NET10 CSR at NET10 Forums:
From the home screen, press Menu
Select "Settings"
Select "Wireless and networks"
(make sure that "Flight Mode" is unchecked)
Select "Mobile Networks"
(make sure that "Use packet data" is checked)
Select "Access Point Names"
Press Menu
Select "New APN"
The following fields appear:
Name: Straight Talk (or NET10)
APN: att.mvno
Proxy: proxy.mvno.tracfone.com
Port: 80
User name: leave this field blank
Password: leave this field blank
Server: leave this field blank
MMS proxy: mms2.tracfone.com
MMS port: 80
MCC: 310
MNC: 410
Authentication type: None
APN type: Not Set
Press Menu
Select
APN: wap.tracfone
Proxy: Not set
Port: Not set
User Name: Not set
Password: Not set
Server: Not set
MMS Port: 80
MCC: 310
MNC: 410
Select "Settings"
Press Menu
Select "New APN"
APN: att.mvno
Port: 80
MMS port: 80
MCC: 310
MNC: 410
APN type: Not Set
Press Menu
Select
