These days it shouldn't make a difference. Most Fast Ethernet and all Gigabit Ethernet interfaces have the capability of sorting out the signals without having to switch between normal and crossover cables. (Traditionally, an Ethernet "patch cable" used on an Ethernet patch bay will be a crossover cable.)Just reg 5e cable or a 5E patch cable???
IME with cable modems and DSL media converters, most of them have the cheapest Ethernet PHY that they can find. Many that I've seen do not support auto-MDIX. If your Xbox has auto-MDIX, then you should be able to use any Ethernet cable anyway.Was gonna plug the xbox right into the "modem" box.
RJ11 is used for single and 2-line phones, usually in homes. If you want to carry Ethernet, You'll need a full 8P8C connector. RJ45 is the connector that Ethernet cables use.
The line from the wall plug to the modem is a network 5e cable, but it has RJ11 ends on it for some reason.
Im trying to move the modem 25ft to central of the house first.
Is this a DSL modem? If it is, that explains the RJ11 connectors on the cable you're describing. DSL uses standard phone lines (2 conductor) to communicate.
