new battery
  • Start date Start date
A
Android Question
Guest
How can i increase my galaxy s2 battery s life ? is it new battery suitable for s2 with more than 1600MA in the market?
Welcome to Android Forums.
Turn off GPS, Wi-Fi, sync, Bluetooth and 4G when not in use.
Watch for apps that update too often (email), kill background apps (stock task manager). Low signals (3G/4G) will drain batteries quickly.
Running CPU a moderator like Voltage Control can under-clock your CPU and extend battery life.
If you install an extended battery it will change the back-plate to an uncommon size.
