new bee need some basic help
i m a new bie just got my new xperia x8 ... plz help me some more basic problem....
1)there is no profile system like we have in nokia phones.... for setting ringtones only or vibrate only etc
2)under setting option its shows memory space for memory card & phone memory... i wana see break up.. so that i know whts going in phone meory specialy since its storage is limited and can i put in any settings so that all applications goes only in memory card
3)i dont like conversation style of messaging can i have differnt folders sytems like inbox,draft,sent itmes,delivery reports like nokia phones ? or atleast can i generate folders so that i can keep msg in diff folders like jokes,adults,etc
On my phone you can change this in settings. Also, you can hold down the power button to switch to vibrate mode.
Or, try using an app like Settings Profiles. Home Setting Profiles
You mean "breakdown" not "break up". A break up is when you and your girlfriend decide to stop seeing eachother.
Go to Manage Applications, hit Menu button and then you can choose to sort the apps by size. This will tell you which apps are using the most space.
Are you talking about Gmail, or about your SMS messages?
Assuming you are running Android 2.1, it unfortunately does not support saving installed apps on the memory card.. that requires 2.2 or higher, unless rooted.
yes i m using 2.1 ....... thats pretty bad that it dost not support this stuff.... can i upgrade it to 2.2 ? or is there any way or there is no way for the time being ?
its paid .. can u tell me about any free application ?
i just wana that all applications r stored in memory card....
i m talking about sms messages
There is a free version you can try. If you like the app, you should support the dev and pay for it.
Tasker will also do what you want, but (again) it isn't free.
If you just want to be able to switch to vibrate mode quickly, there are free widgets that can do that. You might already have it on your phone, or search the market and find one.
