new member- need help
Hi,
Am a new member, got a galaxy ace and have spent 2 days trying to it set up for internet. Have rung up and got settings from samsung and followed your answers to others but it still says no network.
To connect to wifi, you need a wifi signal. If you aren't running wifi in your house for your computers, you aren't going to get it on your phone when you're in your house. (Wifi doesn't just "come in" off the air like phone service.)
You can try at a public wifi spot. If you're in the US, that would be Starbucks or most McDonalds - or anywhere else y9ou see a "public wifi" decal. (A local supermarket has wifi in the store.) If you're not in the US, post your country and someone there can probably tell you where you can find a public wifi. (They're also called hotspots.)
Yes wifi can be found at any fastfood joint and also dd aka dunkin donuts . But any fastfood or convince store such as wawa 7eleven royalfarms and etc . Or you may find a generous neighbors that maynot have a locked wifi .
