If your rooted,You can use a file explorer like this with there root addon: https://play.google.com/store/apps/details?id=nextapp.fx&hl=en
Root addon: https://play.google.com/store/apps/details?id=nextapp.fx.rr&hl=en
And you can go into the system apps and delete what you want.But if you screw up and delete a system app,Your phone can become useless.
None rooted Method to disable apps.This is what I did.
Go into settings>>>apps>>>all and tap on what app you want to disable and clear cache/data and tap on disable and uncheck notifications,And then force stop.
