Hi all,
Hope someone can help me out. I've been reading through the forums and trying to learn more about how memory is managed with Android, but I still feel pretty lost. I'm new to the entire Android experience, so I'm going to assume most of the issues I'm having are user error, and hope I can learn how to handle them better.
I've got a Sprint HTC EVO 4G. I've installed a fair number of apps, but I don't think anything excessive; Yelp, Amazon, Kindle, Layar, RadioTime, myPod, doubleTwist, Twitter, Flixster Movies, Shazam, ESPN Scorecenter, PdaNet, Meebo IM, Gmote, ACV, ShopSavvy, Mint.com, Battery Left. I had initially installed ATK too, but after reading various threads warning against using task killers, I uninstalled it.
The issue I'm having is that it seems like it is performing pretty sluggishly - most everything I do, it seems like there's a noticeable delay (scrolling, opening up an app, holding the Home button down to switch apps, etc.). The worst behavior I've encountered is that 4 or the last 5 times I've gotten a phone call, when I try to slide down to answer the call, the phone is non-responsive, and by the time I can slide it down it tells me I've missed the call. This is obviously pretty frustrating.
When I go into the Settings: Applications: Running Services section, I am finding that the Avail memory seems to continually be dwindling. This morning it said:
Avail: 23MB+0.00B in 41 Other: 0.00B in 4
When I closed a running service (say, one of the sprint ones that seems to start up on its own), the numbers would jump up to something like this:
Avail: 23MB+200MB in 41 Other: 59MB in 4
But if I went back a screen and then viewed running services again, it would be back to:
Avail: 23MB+0.00B in 42 Other: 0.00B in 4
So I'm not sure if this is trustworthy or if it even matters.
The other issue I've had is generally with some apps that seem to be starting up their own services even when I don't want them to - GTalk seems to start by itself, myPod seemed to start all its services by itself, etc. I can't tell if that is part of the issue or not (i.e. when I kill one of those services it temporarily seems to increase from 0.00B to some larger amount, but again, only until I go back to the screen).
What I'm hoping to get a better understanding of is what, if anything, I'm doing wrong, and how I should be handling this. I hope it isn't the small number of apps I've installed, and assume it isn't given that it seems like people often have many more apps and no issues.
Thanks!
-Zadillo
Thanks!
-Zadillo
