Hello all. I have an irritating problem with facebook checkins. Basically I go to check in and am greeted with a list of places nearby to me including my home as it was created by my other half. This makes checking in there very quick indeed as its usually top of the list when I'm there. My problem though is when I go to check in somewhere the place I'm looking to check in to isn't in the nearby list. No biggie I simply go to create a new place, enter a name and description etc and then I'm able to check in there. My gripe is though my newly created location doesn't seem to get saved and if I wish to check in there again I have to add it again. Its very annoying.
Is there a way where I can create a new place and actually have it saved so when I'm back in that area again it will appear in the places nearby list so I can just tap it and check in rather than having to add a place etc?
I use a few facebook apps that can allow checkin etc. Currently have facebook for android, FriendCaster and hTC Friend Stream. I tend to use Friendstream most often for check in as its on my home screen so its just a matter of tapping the check in icon but I have also used the others for checking in but again my new check in doesn't get saved to nearby places.
Any help on this is greatly appreciated.
