newbie needs help with sd card
mebwdb
Newbie needs some help!
Does anyone know how to use the SD cards?
I've downloaded some music onto an SD card and don't know how to access it?
Any suggestions?
Thanks
First off welcome to the site :hello:
Second, please tell us which device you have and which carrier you use so that we can at least start to give you some help.
Any suggestions?
Thanks
Any media player will automatically add downloaded media files to music player through a media scan. If you open music player and they are not there, download an app from the play store called Rescan Media and run it, they should then be in your music player play list. It is more dependant on your Android version then anything else.
