K kyle1745 Well-Known Member May 8, 2010 #1 Does anyone have the details to what additional features are in NewsRob Pro? Other than removing the ads what else?
C cjre3 Lurker May 8, 2010 #2 Hello Everyone, I just got this phone and need some help. 1. How do you get the G- calibration to actually work, its on a level surface and it wont stay in the middle? Also, 2. how do you get the screen to turn when you turn your phone. Sometimes it does not turn and sometimes it takes 5-10 seconds. 3. Another thing, how do you set the phone tot turn off at night and back on without an app? if I need a app, which one is the best? thanks.
Megs Well-Known Member May 9, 2010 #4 I know you can set up widgets with the Pro version. Multiple ones for different feeds too. They're 1X1 widgets. Beyond that I don't know (even though I'm using it). I bought it basically for the widget. *shrugs*
K kyle1745 Well-Known Member May 9, 2010 #5 I wish they listed the features. They might sell more if they did. I want the ability to send the feed in a email along with a link. Sent from my ADR6300 using Tapatalk
