Nexus 4
  • Start date Start date
A
Android Question
Guest
My Nexus 4 phone will not connect to my laptop which is using Windows 8
It depends on how you're trying to connect the Nexus 4. If you want to connect it in order to simply drop and drag files to and from the device, then it sounds like the mtp drivers aren't getting automatically installed correctly. If you're looking to use adb or fastboot to unlock the bootloader or other various things, then those drivers aren't installed and are much more difficult to install because windows 8 is very strict about installing unsigned drivers.
To know which one you're attempting to do and continue, I would recommend signing up and responding to this thread with some more information. Then things can proceed from there.
