Nexus 5 Calendar
Ebarr
I have a corporate exchange email account that syncs with google calendar on my Nexus 5 plus my Gmail email syncs with calendar. What I can't seem to work is I have a third email account that I cannot sync with calendar. When I enter a new event on calendar it does not give me the option or does not show the third account. Anybody out there can help me?
Obvious question-- does that account sync with Google Calendar? The calendar app can only use Google calendar.
Thanks for the reply Hook. It is a POP account that I setup on my Nexus that I would like to have a seperate calendar on Google calendar. When I hit new event in Google calendar it gives me the option to schedule the event under the exchange account, google account but not the pop account.
So, does this POP email account have an associated Calendar you are trying to connect? Again, it depends on whether that calendar gives you a means to sync with Google Calendar, not your Nexus 5. If it can, then you will have that Calendar on your Nexus 5. If not, then you won't.
My POP email does not sync with a google calendar. Why is that? Can I setup a separate account for Google calendars without a email account associates. I am trying to setup my three calendars, each with its own Color so I can differentiate each of them. I have setup my exchange calendar, my Gmail but unable to sync the POP email. Can I setup my third calendar without a email account so it has its own Color? Any suggestions? Thanks.
