Hey, sometime now I had noticed my phone is slow and freezing up. I had tried using that Wugus tool numerous of times to do a restore but it is still freezing and still slow. So, what would be the best thing to do? For service I am using Project Fi.
Are you on the stock ROM/Kernel? Are you rooted?
You mentioned "Restore" - what did you restore (from/to)?
Is a factory reset an option you'd consider? (it will wipe your data)
Clear the cache from the recovery menu. You can google how to do it.
It works but maybe 2 weeks later you have to do it again to speed up your device. Is there any other way better?
