nexus 7 will not charge
  • Start date Start date
A
Android Question
Guest
Nexus 7- i have tried all the tricks and it still will not charge or power on. the battery icon is static no bolt or pulsing to indicate charging and when i try to power on it just cycles from "google' to "X" and back over and over. removed the back cover and checked battery connection. could the battery just be bad?
Hello and welcome to Android Forums.
Sounds like you may be boot-looping, we need a Forum member with N7 experience to help out here.
For your charging problem ill suggest you to try the following one by one till you solve your problem:
1- Try a new or different USB cable
1- Clean your Device USB port.
2- Try a new or different battery.
If none of the above worked, then i would say your USB port is damage and needs repair, even though it doesn't look damage from the outside.
I hope this answer has assisted you with your issue! Please note that if you have any questions you can easily resubmit another question using the same
i am the original poster, now a member.
thanks for the reply, i have ordered a new battery and will follow up if it works.
