pilotcharles747
Nfl superfan debut today on the droid. I gove it a 4.5 out of 5. The app worked just as good if not better than the app on the iphone 3gs. For those who are gonna use it here are some important tips; because i noticed people giving bad ratings because they may be unfamiliar with the streaming. The same problems people complainted about are the same experienced on the iphone.
Tips:
1) You can only watch Sunday afternoon games (blackout restrictions apply)
2) you must have directv, the app is free because you pay directv 69 a mnth.
3)even though it will play on high res I recommend you put the setting to low res...its just as good and its runs smoother (less choppiness from phone trying to deliver high res on 3g)
4) stay in one spot if possible..walking around while using the program causes choppiness.
5) if the program freezes return to the home page then reset ur phone....if u reset the phone while in the program it will thing you are logged in so when you try to log back in it will say you are logged on another mobile device (if that happens give it 5 mins, it takes 5-7 mins for it to recognize you reset your phone) thenn log back in.
Finally) enjoy......if you looking for hd quality video go to buf wild wings..but if you like me and work on sundays its a great app. I hook the phone in to my boombox and listen while I work.
Tips:
