mylittlebambam
Hi,
I'm on Virgin Mobile and I upgraded from CM12 unofficial a few days ago to CM12.1. There was no LTE, so I figured I'd give another ROM a try and see if anything would come up. No LTE, but 3G worked just fine with LTE switched off. However, my APN settings were completely blank, I couldn't use the stock messaging app for sending or receiving MMS, as an error would keep popping up. I switched to GoSmsPro and MMS seemed to work better, but still not perfect. Anyway, I went to upgrade AICP to the latest 09 release, and upon powering it up, I went into settings and switched LTE on, just to test and see if it would work. I also went into the APN settings to find two options actually listed there. I selected the one that read something about LTE and then exited the menu, turned off my wireless internet, and waited for my data to turn on. Nothing happened. I went in and turned off LTE again, and still nothing happened. No 3G, nothing. My APN settings are now gone as well. Anyone have any ideas? Hopefully ones that wouldn't require me wiping my phone and starting with a fresh install of AICP?
Thanks in advance for your time!
