no Android SDK box while installing Android studio
Alexcol
Good evening, i need your help please
I am a newbie about developing tools, and i am taking a course, and i need to install Android studio, and tutorial recommend the Android SDK and Android Virtual Device boxes be checked , the problem that Android SDK is missing at the moment of installing
I have unstalled and installed hundred of times, and have no succeed, i have googled and i have heard that has something to do with jdk version, and hundred of theories, and it is driven me crazy.
because i have 0 experience and developing and installing these tools, i need your help and recomendations please
what should i do in order he Android SDK be displayed at starting installing Android studio
can i continue the typical installation and install SDK thereafter?
i would appreciate your help in advanced
I have java 8 installed on linux, though Android Studio comes bundled with java to make it easier for beginners to install. The installer sets up everything automatically for you.
The best tutorial to follow would be in the following link which includes both a written and video tutorial for the supported operating systems.
https://developer.android.com/studio/install
Thank you very much for your help, i downloaded the latest version for windows but i still faces some troubles:
1.In the tutorial says: Leave the Android SDK and Android Virtual Device boxes checked because they will be needed later
The problem when i start my instalation displays 2 boxes: Android studio itself and Virtual Device, but Android SDK box is not displayed
2 After installing and launch AS there is no wizard to guide me and follow the instructions as a newbie, and select the option:Open an existing project in Android Studio
3 because there is no wizard,i choose Open an existing project in Android Studio, in the tutorial asks me to walk through the path:
C:\Users\Pablo Alejandro\Desktop, then i will find a SharingApp icon, but there is no SharingApp icon in this path, there are 2 shrtcuts: eclipse and videos and no more
The reason is because i started a course: Capstone Assignment 4.1 – Determine the app's information needs, but I am completely stuck
Thank yoy very much for your help in advanced and thank you for bearing with me as a newbie
Before importing a project into AS, you should first make sure that AS is installed and working correctly.
  1. To do this you should start a new project.
  2. In the next screen choose Empty Activity.
  3. In the last screen give your project a name.
  4. Language = java
  5. Minimum API level - leave at default
  6. Leave the boxes unchecked and click finish
If the new project is setup without any errors then all is good and you can proceed with importing a project.
Thanks u again four your support.
I started step 1 but failed, yileds and error related to SDK is corrupted or out of date
Your Android SDK is missing, out of date or corrupted
I clik on the Open SDK Manager botton but it does not make do anything
I uploades screen errors
i have no idea whats wrong, but Could u tell me if has something to do with windows license, i just realize is not active
Thanks four your help in advanced
You see in the first picture, click the edit button and enter the SDK directory path that you have in the third picture.
OK thank you, i did, now it lets me follow the steps to start a new project. i did not see errors but it warns me the path location should not contain white spaces because its probably i will have problems with NDK tools later on
So i can proceed with the Capstone course tutorial?
The white space it's talking about is probably the space in between "Pablo Alejandro" in the SDK path. It'll probably be OK, I can't say for sure since I don't use windows.
If the new project was created fine, then you should be able to proceed with the Capstone course. Good luck.
