No Audio on Galaxy S3 Mini
  • Start date Start date
A
Android Question
Guest
Good day... I've been using a Samsung Galaxy S3 for some months now and everything was running smoothly. Two days ago after I rebooted the phone due to a flat battery, it began not giving me sounds on anything i.e. I can only hear sounds if I have my headsets connected. Nothing comes through the loudspeaker be it music, notifications, radio or calls.
Can you please advise of any other options as I've already checked all settings and volumes including the ones on the side of the phone.
Sonic4urMind
Do me a solid Sonic4urMind, go into Settings > Accessibility > Turn Off All Sounds and make sure that the checkbox next to it is UNCHECKED.
If it is checked, uncheck it and you're set :)
If not, reply here and we'll look for another fix ;)
