No carga mi andrid
  • Thread starter Thread starter MIKE VELAZCO
  • Start date Start date
M
MIKE VELAZCO
Guest
Por que no agarra carga mi android huawei de metro pcs?
Hi,
For your charging battery problem, i suggest you to try the following one by one till you solve your problem:
1- Try a new or different charger.
2- Clean your Device USB port.
3- Try a new or different battery.
If none of the above worked, then i would say your USB port is damage and needs repair.
Translated to spanish/Traducido al espa
