Sterlsilver
So when the merge is complete and the cdma gets shut down does that mean I can't switch the Galaxy s3 to cdma(3g) when I want to save battery and the signal would be stuck on LTE??
That's correct but with VoLTE you can put it on LTE only which will stop the CDMA & EvDO radios
that will be a huge battery killer. 4g should definitely be turned off and use 1x/3g or wifi to save battery life and to use the 4g when you really need it
Right and if i want the galaxy s3 i would at least be able to switch it to 3g.
If all else fails I'll just turn the data off if all else fails.
but why you do ever want to go back to 3g when LTE is way better, and it'll even better when they bet rid of cmda....
Well since lte kills the battery i would want to switch to 3g and conserve battery.
Also when the 4g signal drops then what? There would be no 3g to go back to
Ok i think I'll just get the s3....at least it still works because it's also lte![]()
its not gonna happen for another 3 years. by that time the phones we have now will be dinosaurs, LTE will be built out into all of T-metro's spectrum and phones with LTE will be more energy efficient.
not something anyone should worry about at this time.
That's true, I'm not quite sure why people are worrying about it
voLTE will be up and running in all metro markets by spring of next year so you might NOT need the CDMA radio anymore. though im not sure how they're gonna run that for legacy LTE phones.
