Help No data connection after firmware upgrade!!
Lulu3
I upgraded my S3 to the newest firmware/software the other day. Since the upgrade, I have lost all data connectivity. As soon as I'm out of my wireless zone (wireless works fine), I have NO data connection whatsoever. I tried rebooting, toggling on/off airplane mode, taking out battery/SIM card...nothing is working.
Any ideas???
try a factory reset it should solve the issue. Also you should check and make sure the access points settings for ure 3g are still there.
