I am running 2.2.1 on a Mytouch 3G everything works great. But when I try to download flash 10.1 it tells me not compatible with my device? Does that mean my hardware won't support it?
Yes, that's exactly what it means. 2.2.1 is not enough. Your hardware also has to support Flash, and the MyTouch 3G does not (I know--I used to have one).
If you upgrade to the MyTouch 4G, Flash is supported.
