Help no notification when another call comes in
donmeca2020
while on a call tonight, i came to notice that i dont get any sort of sound or tone when another caller is calling. is there anyway to rectify this ? my old optimus M would make a sound when another caller was calling. i would love to fix this
Open up your dialer, press menu, call settings, additional settings and make sure call waiting is ticked.
as i checked to see if this was clicked on, it actually was.... so i unclicked and clicked on again. hopefully this will remedy the issue, because everytime im on the phone if i get a call i always miss it.
even when call waiting is checked (or enable), the audio is very very slow. i installed call waiting configuration app but it leaves a lot to be desire either.
i wish there is a GOOD app out there that for call waiting. i agree often times people miss the second incoming call.
my problem was fixed when i reapplied the regular incoming call sound. also it might help if you increase the in call volume possibly?? i havent missed any other calls and now i do hear the sound.
how do you mean by 're-applied the regular incoming call sound?' my call volume is already set to 100%
where do you set this? i honestly do not even hear the beep? does it only beep once or keeps on beeping during the entire time the second call comes in?
same way Shotgun explained - Open up your dialer, press menu, call settings, additional settings and make sure call waiting is ticked.
mine was already clicked on, but i unclicked it and clicked it again. as for the sounds go to where you can adjust the volume of everything and just completely turn them up. only one i did not turn up completely was the ringer because half way it, was very loud.
i did what you suggested, de-select call waiting then select again. i only hear one beep when a second call comes in. i was hoping the beep is continuous for at least 4-5 seconds. how many beep do you get?
i think i could be wrong, but i think its a beep beep. if thats not good enough for you. i would suggest searching for some sort of app that can change this.
two single beep beep, to be honest, is barely audible when you are outside. i have installed call waiting configuration which gives me four vibration which helps a lot.
thanks for your help in this matter nevertheless.
