no one can help me!!!!
  • Thread starter Thread starter Carolyn dale
  • Start date Start date
C
Carolyn dale
Guest
How do I download this thing.Even the guys at Best Buy couldnt download it. I hate this product.I just hate it.And it doesnt connect with any thing.its just junk,I got totaly ripped off.
Hi Carolyn and welcome to android forums. Unfortunately, without knowing what the thing is you are trying to download, or the device you are trying to download it to, there is little advice i will be able to give you.
If you would be so kind as to resubmit your question with some additional info, we would be happy to try and get this sorted out for you.
You can either use the guest question form again, or you can sign up (for free) as a member and reply directly to this thread.
Please try to include as much info as possible. such as:
-your device
-what you are trying to download
-what happens when you try to download it
hope to hear from you soon :)
