Help No Power - No Charge Indicator
Pootio
So I just replaced the LCD/Digitizer on my LG G2 and all was well.
I plugged in the SIM, rebooted the phone, and now it won't turn on.
No Signs of life at all, not when plugged in, nothing.
I've held the power button, hooked to my PC, tried Volume+Power buttons, etc.
The only issue I can imagine is that when I put it back together, I accidentally mixed up the antenna cables.
Would a bad battery cause this? I had like 70% left in the battery before rebooting, but now it won't even show that it wants to charge.
I reseated all of the flex cables and ensured that everything else was fine, it was just the backwards antenna cables that I put back correct again.
Any advise would be greatly appreciated, this phone is out of warranty.
Hi, was there any resolution to your problem? Seem to be having the same issue where after replacing the lcd assembly the phone act as if there is no power.
Thanks! that was our next step. just tried replacing the main flex cable due to the battery seemingly taking a charge prior to replacing the assembly.
Thanks again.
