Something changed recently, causing me to lose the sound preview you normally get when choosing a Notification, Ringtone or Alarm sound file. Checked that system sounds are turned up. The sound selection page is different than it used to be, almost like it's being controlled by a different app. Not sure if an Android system update has done it, or a setting I changed by mistake? I looked at my installed audio apps but see nothing like it. I'm on 7.1.1. This has always worked previously. The selected sound does play when it should. Here's a screen capture video (can't get sounds) showing what it looks like
