No sound when sending an email
Mark2801
I have finally moved over from IOS after many years and love my new Samsung S7 Edge but one feature that I liked on iPhones was the whoosh sound when sending an email. I understand this is not available on the Samsung Email app and nether on the Gmail app. I have also been told that this could work if I set up some rule using the Tasker app but I have downloaded that and it looks very complicated!
Anyone know if any other email apps offer the ability to provide a sound when you have sent an email?? Thanks in advance for any help!
As much as I love Tasker and his power, I often use MacroDroid. It's far simpler though not as powerful. It will easily do what you are looking for. If you're committed to Tasker I can lay out the steps for you.
Thanks, I already purchased Tasker but not that fussed if I have to spend a few more pennies on something that was easier to work out or if you have the time then the steps for Tasker would be great!
no whooooosh sound.....
the only setting for sound notification is when you receive mail in Gmail......
Post the steps if you can, I would like to know too.thanks
