So - I *love* Google Maps with Navigation and I just recently upgraded to the new version of maps where it gives you a direct link to Navigation.
My issue though is that I do not have any voice navigation when I start Navigation directly but I do have it when I just go through the regular Maps link and then select Navigation in there.
I checked the menu and it is not muted. The sounds is also set to high. As I said, the sound works perfectly well if I go through the main app. Just not with the new direct link.
Anyone else seeing this or worked this out?
Thanks
Glenn
Thanks
Glenn
