Help Nokia 6.1Plus caller screen colour is not changing
Hi I Have purchased nokia 6.1 Plus, Here my caller screen is not getting changed while trying to change through changing the sim colour.. It's always remained white only..but while i have purchased it the screen was blue...
Has the Phone app been updated recently? If it's using Google's Phone app the most recent update replaced the blue call screen with a blinding white one (and introduced a sickly pastel colour scheme for contacts).
Yes, it's ugly. You can complain to Google, but they don't listen to users. Or you can uninstall updates to the app (and turn off auto updates to it) to get the original version back. Or you can find another dialer. I'm afraid those are all of the options.
When this blinding white background showed up on my phone, I figured out to disable the updates to get rid of it. Very annoying to say the least.
