thx for all your help.like i mentioned in my original post,i am clueless when it comes to tech.with that said, could u please lemme know exactly which files to download from this link... SCH-R740C Samsung Galaxy Discover Cricket CWM touch - xda-developers
Depreciated -- Odin + R740c CWM Touch Recovery -- Depreciated --
Odin V3.07.zip
Stock-boot+system-R740CVVBNA5.tar.md5
Stock-recovery-R740CVVBNA5.tar.md5
CWM-recovery-amazing3gcri-eng.tar.md5
ill read the thread for step by step instructions i just need to know which files i need.
Ok, I can give you a bit of a run down,
Odin V3.07.zip - This is absolutely required to 'custom flash' your phone
CWM-recovery-amazing3gcri-eng.tar.md5 - This is the custom recovery (needed to flash custom update.zip files)
two files not mentioned here but available on the first post are:
Stock system/boot/radio 4.1.2 update for CWM
amazing3gcri_stock_4_1_2.zip
Naked ROM 4.1.2 Preview update.zip for CWM
amazing3gcri_unsigned_020214_231354.zip
*** I would use one of those with the CWM flash (lots of guides available for CWM) to upgrade your phone to 4.1.2 to avoid having to manually DD the modem.bin to the device..
the other option is:
Odin V3.07.zip -- Still required
Stock-boot+system-R740CVVBNA5.tar.md5 -- System+boot
Stock-recovery-R740CVVBNA5.tar.md5 -- Recovery
4.1.2 modem.7z
Follow the instructions on the initial post, using BOTH tar.md5
boot into the AOS, turn on usb debugging
1) download modem.7z
2) extract modem.bin
3) place on sdcard
4) run cmd:
5) adb shell
6) su
7) dd if=/mnt/extSdCard/modem.bin of=/dev/block/mmcblk0p3 bs=4096
8) wait 2 mins after it finishes writing and execute reboot
