Normal Battery Temperature for Galaxy S5?
mempto
So I know this is a common question, but I just wanna make sure my Galaxy S5 battery is working properly. Under moderate usage, it easily gets within the 36-38 Celsius range. Is that odd or typical of these phones?
It depends on the ambient temperature (the temperature of the air the phone is in) and the amount of motion of the air. A phone in an 80 degree wind would probably run cooler than a phone in 75 degree still air.
On a really hot summer day, when the air is 100F (38C), the battery can't be lower than that, so a battery that's 38C is like one that's not even in the phone on a really hot day. Since the battery generates SOME heat, 40C on a hot summer day would be low. (Out in the open, in the Antarctic in winter, that would probably be a battery that's about to explode.)
We'd need the ambient temperature when you measured that battery temperature, but in any environment that's at least somewhat comfortable to you (IOW, not more than about 110F), 38C isn't high for a battery.
it also depends on your signal strength, especially if you're on Verizon or Sprint. they can become very hot in a pocket if you're in a low-coverage area. you'd also probably notice degraded signal, loss of data services, and even phantom rebooting (Android is sometimes coded to reboot if it gets hot enough.)
