Felter Hills
Hi Experts:
I got a new cellphone (UMIDIGI Power 3) and it worked for a few days. Today it suddenly shut down when I was trying to start the MS Outlook app, afterwards it cannot longer complete a boot up. It shows message "dm-verity corruption Your device is corrupt, it can\\\'t be trusted and may not work properly. Press power button to continue.Or, device will power off in 5s" and then shut down. I tried to use factory reset and was able to boot up successfully but the phone behaves the same if I try to reboot it (show same message "dm-verity correction ..." and shut down by itself.
My questions are:
1. Is this a hardware issue or a software (Android OS) issue ?
2. What is the root cause ?
3. How to fix it ?
Thanks
Felter
My questions are:
3. How to fix it ?
Thanks
Felter
